Scott H
Cast Iron
- Dec 2, 2001
- Covington, VA
I have a Harrison VS450 flat bed CNC lathe. I have a bad bearing sound when running in the low speed range of the 2 speed gearbox. When I run in the high speed range everthing sounds fine. I am assuming that the bearing under the high speed clutch that allows it to freewheel while in low speed is bad. Does anyone have any experence with replacing this bearing? Does anyone have any exploded prints of the gearbox or parts list?
Scott
Scott
