Atomkinder
Titanium
- May 8, 2012
- Mid-Iowa, USA
Countersinks in Thin Plastic
We're having an issue with running a countersink in a relatively thin plastic disc.
The part has a through-hole and we're using a 3/8" MA Ford single flute 100° countersink but getting inconsistent results even with a dwell. I suspect the single flute is causing oscillation in the surface (there's a clearance channel in the fixture under the part) giving us poor consistency. The disc is about .116" thick and the countersink varies from .13" depth to .144". Part of the issue might also be the diameter of the cutter, but I wonder if a zero flute or multi-flute tool would be better in order to keep pressure on the part to keep it from rising in the cut.
Any similar experiences are welcome.
Current parameters are 1222 RPM at 7.334 IPM, started with an air blast, and removing it made no difference (was curious if the air was blowing the part up off the fixture slightly). Plastic material seems very similar to Delrin.
I might be able to take a few photos if anyone things it would help.
