A bit late but perhaps help to someone else.
Regards,
Bill
Siemens parameter settings
#5010
(Handshaking) = 0 (RTS/CTS)
#5011
(baud rate, parity, stop bits) 11110111 (9600, Even parity, 2 stop bits)
#5012
(Handshaking) = 0
#5013 (baud rate, parity, stop bits) 11110111 (9600, Even parity, 2 stop bits)
#5016
bit 5 = 1
bit 4 = 0
RTS Line = 1
Following are other settings for parameter #5011,#5013 above
Baud Rate Parameter value
1200 11110100
2400 11110101
4800 11110110
9600 11110111
PC Comms Software settings
Handshake Method = Hardware (RTS/CTS)
Baud Rate = 9600 (or to whatever the control parameter is set to)
Data bits = 7
Stop bits = 2
Parity Bit = Even
Cable Configuration for DB25 to DB9 connectors
Machine Side -------------------- PC Side
DB25 Male Connector ----------- DP 9 Female
1 --- Shield Trace ------------ Not Connected
2 --------------------------------- 2
3 --------------------------------- 3
7 --------------------------------- 5
5 --------------------------------- 7
4 --------------------------------- 8
6
8 All bridged
20
