Countersinking 500 BHN Wear Plate
Results 1 to 8 of 8
    Apr 2009
    CANADA
    Ontario
    1,555
    534
    486
    Default Countersinking 500 BHN Wear Plate
    Hi guys. I have a lot of wear plates that we are constantly needing to countersink. Usually 11/16 and 13/16 holes. I have 2 tools right now for the manual drill press with a #4 taper. They works ok but the problem is there is only 1 insert on the tool, in turn forces the radial arm to the side. They have 11/16 and 13/16 respectively pilots at the bottom for locating. I was looking into getting a tool with 2 inserts but can't seem to find any. I had Company A and company B quote me prices to make one but of course they are ridiculously priced and I can't justify it. Do you guys know of a company that specializes in these types of tools that I can get a hold of? I am in Canada. Thanks.
    Aug 2006
    greensboro,northcarolina
    2,140
    108
    400
    If I understand , you want a 2 or more flute insert style countersink 82 degree with an 11/16 and 13/16 pilots and a #4 taper shank? I've never seen one that was not custom made, probably going to be pricey.
    Apr 2009
    CANADA
    Ontario
    1,555
    534
    486
    That is exactly what I am looking for. I was afraid of that answer. Thanks.
    Apr 2006
    Westside of America.
    3,291
    670
    890
    I've never been one to make something when I can just buy it from somebody else - but this sounds like a fairly straight forward do-it-yourselfer. Do you have a CNC mill and a manual indexer?
    Apr 2009
    CANADA
    Ontario
    1,555
    534
    486
    Yes I do however we are so freakin busy right now, I can't afford to take any time off the mill. I only have one. I am having another company taking a look. He said he might have a solution. Thanks anyways fellas.
    Feb 2006
    Republic of Texas
    2,259
    Does Everede Tool Co. have anything that will work? I swear I saw a tool with a .688 min. dia.
    Jan 2007
    Norfolk, UK
    17,039
    12686
    12217
    Have you looked at Granlund modulars ?
    Prob #1 for your size
    Counterboring System Size 1 - Granlund
    PDF catalouge
    http://www.granlund.com/files/f7dcb4...cb8ed8b1ff.pdf
    They do an insert for Hardrox
    Mar 2012
    Quebec, Canada
    625
    88
    200
    we made some at ours shop custom made with some boring bar insert work realy well in Hardox 450 wear plate i can give you the insert shape if you need to not that hard to make and realy worth it.
