Cutting hard steels...
very good question most likely not that hard.
its one of the vise jaws from orangevice, on their site looks to be 4140 Semi-Hard.
I'm pretty interested in learning the hardness of steels what makes them hard, how to cut them etc...This is where im very green.
When I was doing my first 4140 pH machining not too long ago utilizing info and support from the cutting companies was useful. Sandvik, horn, and sgs all had pretty good tech support
Something is horribly wrong. You should not be seeing sparks. Sparks mean your RPMs are too high for the feedrate you are using.
With good HSM tool paths and coated end mills, you can run 4140 HT pretty aggressively.
I would run about 800 SFM, and at least .006 per tooth feed, 10% step over at 2XD. I run a 1/2" 4 flute HTC variable flute with TiAlN coating at 5800 RPM, 180IPM, and .05 step over.
Guess I got lucky then :)
11459rpm
30ipm
20% step over at 1x diameter
.250" endmill 3 flute (its all I have on hand at the moment)
put me at 750sfm and .001307 ipt
So I was way off. Endmill is still sharp and the surface finish looks great. Ill have to pick up some 4140HT and some better endmills and make something.
First up, 4140 at 40ish isn't hard. D2 at 62hrc is hard...
Second, like Ewsley said, something is way wrong there. If what you are cutting is actually 4140, it shouldn't be too tough to cut. It is tougher than 1018 sure, but still plenty doable.
You know, Sol (orange vise) is a member here. A quick PM to him about his jaws will get you much more reliable info than just guessing...
Sol is a busy guy, I hate to bother him. I just needed a step milled and I accomplished this on 2 jaws without any broken bits. Next go around Ill know what im cutting and do a little better diligence before cutting.
Back to cutting aluminum for me!
Do you mean to say that D2 at 42rc would still be harder than 4041 at 42rc? :)
Other than that i agree with everything you have said.
In one of his last vids Sol is cutting his jaws and no sparks are seing there.
Like everyone said too many sparks for 40 -ish RC steel.
Imo the chipload was ok for a 1/4" endmill. Tis why it did not break.
But the sfm should have been around half of what you used.
But hey, it worked fine, right? Then you were not wrong!
depends on shape of what you are cutting. if it is easier to endmill rather than side mill then i would try
200-300sfpm
DOC low 0.005 to 0.030"
Feed low at 0.001 to 0.003" ipt
........it has been my experience a hard steel will overload carbide and chip the corners away unless you reduce cutting load in particular DOC and Feed. I have cut hard steel dry and with coolant. If cutting dry the part can heat up and loose its hardness. i have seen many end mills nearing dullness throw sparks and glow red to orange. eventually they get hotter and hotter and part will turn blue (over 600 F). many hardened steels start to loose hardness at 400 F when they turn straw color.
....... i have cut hard steel with 3/4" dia carbide end mills and 2" dia cutter with carbide inserts. it is my belief the larger diameter helps cut faster compared to a smaller diameter cutter. i have cut a lot of parts with 60 Rockwell C scale case hardened parts. as long as you ease up on DOC and Feed it cuts relatively easy. I don't claim to be a expert but i have cut many dozens of hardened steel parts before.
If it's a vise jaw, I would guess that it's hardened to about 50-52 Rc.
Even at that hardness, you shouldn't see a fireworks show.
Our jaw plates are 4140 hardened to around 50 Rc.
With HSM tool paths at 5% stepover for a 1/4" EM, try 300SFM and 0.004 IPT programmed feedrate for starters.
-Sol
11459rpm
30ipm
If that end mill still looked sharp after that fireworks display, I'd stick with those mills. ;)
-Sol
Thanks for real numbers.
That would make much more sense than Semi-Hard, pH, or HT and would explain the "light show".
One would expect a decent 4140 vise jaw to be in the low 50s.
I'd start at 200-300 SFM here with TiALn, 60-80 uncoated, 100-150 with Tin.
I'd also be in a C-5, C-6 tool but most off the shelf stuff nowadays is C-2 micro and the work is done with the coating.
Thermal cracking is going to be a big problem and the extra TaC will help along with the hardness from the added TiC (which is why these are steel cutting base grades).
The OP should at least invest in some hardness files so that he has some idea of what he is working in.
The tool may still look "sharp", not much cutting time and don't know what the OP is using for a microscope.
When it does begin to fail it is going to go to poop very,very fast. Probably much quicker than you can get to the big red button.
Bob
I have made quite a few specialty jaws from standard kurt vise jaws. For a 1/2" endmill 300sfm and .003 ipt with .02 radial works great. Hsm style machining without the high speed makes the endmills last. The trick is to limit the cutters exposure to heat. Also, sparks = bad is not always correct. It depends on the cutter, material, speeds and feeds and coating.
