KaiserGlider
- Oct 8, 2017
- San Diego, California
I will soon be required to cut stock up on the bandsaw and then cnc mill the sides down to the required tolerance, so I was just wondering if my plan will be sufficient or if there's a way to ensure higher accuracy from the get-go.
Let's say after using the bandsaw I have some 6" wide plates that I want to cut down to 5.8" inches. Step one, I stand the plate up in the vise, probe the top for Z and then face off .1" of material. Step two, I flip the plate over, probe the top again and remove .1" of material. I measure the plate to see how close I am to 5.8" and adjust my Z height on the machine if necessary before running the rest of the plates all at once.
