I just got done with a good sized job cutting some aluminum on my Komo cnc router, at least it looked like aluminum, nasty, gummy junk. Anyway, I wasn't getting anywhere until I got a new cutter. Someone on here suggested an Onsrud cutter and I ended up getting a 65 series 'super O'. I was cutting a kajillion 2" square holes in 4x10 sheets and it had to have a 1/8" corner rad, so I used the 65-23. It made all the difference, I ran at 10K and 30 ipm. Could have pushed it harder I think, but wanted to be able to walk away from it so left it at that.
:: Super O Router Bits | Single Edge | Solid Carbide | Upcut Spiral O Flute | Plastic | Wood | Aluminum | Solid Surface | Documents
I watched the video, if you are planning on running these parts often, I'd suggest making a dedicated spoil board for it. Have you ever used any o ring gasketing in your spoil boards? If not, the idea is to offset your cut by 1/8-1/4" and cut a slot to insert an o ring in with it protruding a small amount. Then drill or cut holes through the spoil board to apply vacuum to the inside of the gasketed area. This works great on parts like you were cutting. On ones that are very small I'd still use tabs and trim them after.
I use 1/4" dia round o ring and I cut a 1/4" wide slot 0.200-0.220" deep depending on the material I am holding. If you have lots of small tight spots, you can use smaller o ring cord.
You may also consider drilling the holes first and dropping dowels into them before you start cutting the perimeter out, works good on slippery parts since it can't slide around once you put a dowel in, then the vac only has to keep it from lifting vs sliding too.
Jason
