nitrousmudbogger
- Feb 12, 2013
- Belgrade, MT
Not sure where to post issues with Daewoo/Doosan Machines?
I have a Daewoo MX200ST that started with a huge rats nest of chips wrapped around the tool, did a tool change and dropped the next tool. Machinist stopped machine, cleaned chips out and tried to do a tool change. It will not.
The spindle is clamped and will not unclamp even if a m101 is called out. We have traced everything we know to the solenoid valve for clamping/unclamping. It is constantly powered up on the unclamp side yet spindle is still clamped. If we hit Estop or turn machine off hydraulic pressure goes away and then the spindle turns freely. If I unplug that side it stays locked, if I switch power over to the A side that is supposed to clamp nothing happens. I can hear the valve clicking when touched with power. We took the valve off, went through it and didnt see anything weird. Grabbed a power supply and touched power on each clamp and unclamp solenoids and you can see the valve moves back and forth
Called Doosan, no help yet. One guy said it was over our head and dont bother, get service guy to fly out for $1500/day. I would like to exhaust all my options first
