pdexter1210
- Oct 21, 2014
We're trying to run some double sided 1 1/2-8 studs on the newest Puma 230MSB to test it out and we're having trouble with the 2nd side threads on the sub. It's a proven program from our other machine. Each threading pass on the sub is equally out of time/clock(not sure of the correct term) with the previous and we end up with a very nearly flat looking surface at the end of the threading cycle. There is no backlash in the machine, and the collet is holding accurately, but our sub is out of sync by the same amount with each pass. Front side threads on the main are perfect. 1st pass on the backside using the sub looks great, then gets out of sync. Any ideas?
