pdexter1210
- Oct 21, 2014
We're trying to get a production run lined up on our Puma (Fanuc 18iT) and we're having trouble with the parts catcher. The machine (new to us, but older), originally had a catcher but PO had removed it long ago. We bought a new catcher and hooked it back up per the wiring diagram. We can MDI the catcher up and down with M10/M11 accordingly(its pneumatic), but the machine will alarm out after a period of time given either M code. When it is up, some time passes then it alarms, we hit reset and then we can give the M11 to lower. The alarm message code is No. 2039 (M10 or M11 Command Alarm, Check Solenoid valve, Position Switch and Operation Condition).
The proxy switch is wired as the book says (the light is on and its giving a signal to the control when catcher is in the retract position). There was no wire for a proxy switch in the catcher advanced position, nor does the wiring diagram call for one, but its almost as though the control is waiting for a signal that the catcher has advanced in order for it to proceed.
Any ideas on what could be holding things up when we give the M10 or M11? Thanks.
