aninventor
- Dec 31, 2009
- Ohio - USA
I have always been told to never disassemble a step motor as it ruins them - reduces their output torque significantly by demagnetizing them.
So, is there a problem if you disassemble a permanent magnet DC servo motor? I am thinking that this is not a problem with DC motors in general because I have disassembled many DC starting motors without problems. However, servos may be different - so I ask:
Is it OK to disassemble a DC servomotor to clean it up inside, to replace a bearing, clean the commutators, or etc.?
My servos show very erratic ohms readings across the motor terminals. Turning the motor shaft to different rotational positions gives ohms readings from 3 to over 120 depending on where the shaft stops. I am thinking that this will cause erratic operation as a servo. Am I correct to be concerned? The commutator does not appear to be burned up or out of round or grooved, just very badly blackened by use. There was carbon dust in the brush holder as well. The brushes are nearly full length and in good condition and move freely.
If I can disassemble these motors without reducing their performance, how should I go about cleaning up a dirty commutator? Is it OK to polish them with fine emery paper? Will polishing the bars with abrasives embed grit in the copper and cause excessive brush wear? Do they have to be turned in a lathe to clean them up? How do you guys handle servo maintenance and what should I do to bring these motors up to their peak performance before I install them?
I have a used set of Siemens 1HU3056-OAC01-0ZZ9 and a used set of Baldor 4203623 motors.
I wold appreciate any tips for maintaining these motors.
