DCC CMM with "bad" granite surface- worthless or not ?
Page 1 of 2 12 LastLast
Results 1 to 20 of 27
    Dec 2000
    Coastal Dogpatch, SC, USA
    50,700
    2435
    5274
    Post
    Ran across good buy on small Zeiss, year 1997 DCC CMM of about 20 x 20 travels with automatic probe changer that looks/works great except the idiots mucked up the table by dragging sharp heavy parts that put some pretty deep scratches in the granite surface. Table is integral to the slide so replacing just the granite would be nearly impossible and resurfacing it impractical.
    I would think it would be fine as is if one held the parts to be inspected in a jig/fixture, as long as that jig was always positioned in exactly the same spot on the plate surface...and/or referenced off a ball on the jig...but how many companies actually use one that way ?
    Aug 2005
    Bremerton, Wa
    2,595
    66
    68
    Post
    Correct me if I'm wrong, but when you inspect using a CMM you must first probe the part to establish a datum plane and XYZ zero. so , in reality, the table is only there to support the part and nothing more. It wouldn't matter to the CMM if the thing had a big hole out of it as long as that part didn't move during inspection
    Jim
    Dec 2000
    50,700
    2435
    5274
    Post
    I was thinking the same thing PB, but then I started thinking if that's the case then why do they have precision granite surfaces in the first place and trying to make some sense of how different companies might use them in that light. Could be that granite is simply the cheapest way to produce a relatively flat support surface. Friend of mine has a late Sheffield DCC CMM that appears to have aluminum or Moglice surface and he was saying "well, it's just a cheap model"....whaaa ?? (damn thing was still over $70,000)
    Aug 2005
    Bremerton, Wa
    2,595
    66
    68
    Post
    Ya know, CMM's are a strange animal. Sheffields used to have a steel table. And I have run enough of them to know that if I wanted to hide that little discrepant dimmension from you as you stand there looking over my shoulder. You'd never know that part was scrap.
    I've come to the conclusion that CMM's are really for customer piece of mind. "He's got a CMM...he must do good work." I think there may be some of that with the MFG's as well, because there is no real reason to have a granite plate as all these guys use error compensating software as well.
    They are just eye candy...
    (but I'm not gonna pass one up if I find a good deal on one...)
    Jim
    Dec 2000
    50,700
    2435
    5274
    Post
    Probably mostly so...but handy for reverse engineering of complex parts I should think...don't need DCC for that however...manual would do fine...
    Apr 2004
    Monument CO USA
    2,059
    9
    108
    Post
    There are many parts over the years that I have designed that could only be inspected on a CMM. I don't know of any easy way to do some measurements by hand. It's pretty hard to find the diameter of a discontinuous surface on a plastic piece.
    Chris P
    Apr 2003
    Portland, ME, USA
    2,086
    Post
    So what level of accuracy can you hit with a Zeiss or the like?
    I do all my probing and reverse engineering on the VMC with the "pride of Renishaw".
    Jan 2002
    Upstate NY -In the Flats next to the corn fields
    8,747
    1328
    2194
    Post
    Wonder where the boss or owner was when they were plowing up the table...... :rolleyes:
    Edit:
    Oh, YES it's totally worthLESS.....
    I'll give you $500 for it out of sheer sympathy....
    Dec 2000
    50,700
    2435
    5274
    Post
    Do I have to give you the $25,000 worth of probes it comes with too ?
    Btw, I was walking by the decrepit Feeler lathe the other day and it was asking about you..."what happened to Dan...doesn't he like me ?? I really hate this humid climate and want to go north...HEY, mud dauber...SCAT !"
    Aug 2005
    Bremerton, Wa
    2,595
    66
    68
    Post
    Why, Yes Don, Yes you do...
    Jim
  11. #11
    Mar 2002
    Ramona, Ca. USA
    1,377
    Post
    I am intrested. I got a piece of plywood I could use for the table. How much you gona ask?
  12. #12
    Dec 2000
    50,700
    2435
    5274
    Post
    Treated ? [img]smile.gif[/img] Dunno my sales price, haven't bought it yet...still "dickering" with owner...
    Guess I could spread out some spacklin in the cracks and spray paint it black...
  13. #13
    Jan 2002
    8,747
    1328
    2194
    Post
    Please??
    Oh, and can you retrofit it with that "Cheap-O" new software also, before you ship it here???
    PLEASE??
    Stand by, I'm still getting ready to get my Onmiturn on line, then I can send off a gloat....er.....comparison value for you to consider when you set your "best" price on it.
  14. #14
    Nov 2002
    3,034
    1352
    654
    Post
    Treated ? Dunno my sales price, haven't bought it yet...still "dickering" with owner...
    Ahh hell, Al Babin is back!
    Now we know "the rest of the story" LOL
    Doug.
  15. #15
    Apr 2005
    SE Mich.
    347
    Post
    The beauty about granite for inspection purposes is its low temperature coefficent (5ppm/C); its high thermal inertia making it impervious to short term temperature fluctuations; and the ability to make a very flat surface.
    As far as this CMM goes, you're right, if the operator uses fixtures to stage parts, the granite top doesn't mean much. Unfortunately, a potential customer may wonder in his mind that if the previous owner was so lax in protecting the table, how was the rest of the machine treated.
  16. #16
    Jul 2005
    North(very) West(very) Ohio...near exit 13 on OH turnpike
    3,714
    175
    Post
    Man having a CMM handy is sure nice, I used to grind tapers in carbide and steel and it is a quick and accurate way of checking one. We were told to verify our work by two methods of measurement. Smaller tapers we poured slugs and used optical comparator to check them.
    Bill
  17. #17
    Jul 2005
    San Francisco, CA
    807
    11
    80
    Post
    Who says its a "precision granite surface" many people assume thats it a traceable surface plate quality piece of granite. For the most part its not! Thats why you normally don't use the granite surface as a datum on a CMM.
  18. #18
    May 2004
    Zellwood, Fl.
    1,440
    585
    279
    Post
    Don,
    Pull the granite, send it out have it resurfaced, reinstall, Send it to me to dial it back in with the calibration program. Should not take more than 3 or 4 years (I'd only work on when I was bored have to have the right mind set ya know)to get it right then pay my way to S.C. put me up, feed me, it should only take a month or so to dial it back in on the show room floor then when you sell it elude to the customer after you get the check that it will cost him 30K for calibration at his site. What was I thinking that's your plan of attack.
    Scott
  19. #19
    Jul 2004
    Asheville NC USA
    8,948
    3393
    2978
    Post
    Just getcha a piece of Granite looking Corian, slap it on top of what's there, and point out that it is equipped with the optional subplate
  20. #20
    Jul 2005
    3,714
    175
    Post
    They used to have the same people that lapped our granite surface plates also do the CMM
    Bill
