I bought a BMC25 a few years back direct from Hurco . It has Ultimax 2 ( Max32 ) control. The machine has a fault at present and the text display has stopped working. I have tested both of the CRT driver boards at the rear of the CRTs and have replaced 8 capacitors which were measuring outside of specification. Other than that I could not find any fault with the boards. The graphics screen displays as normal and the machine appears to be working normally, with the exception of the text display screen which is completely blank. If I take the ribbon cable which feeds the graphics CRT driver board and plug it into the text screen CRT driver board I can get graphics display on the text CRT, so I'm sure the CRT is working correctly.
I have adjusted the main power supply voltages to get the correct 5V and 12V levels. Is there any way to identify if the problem lies with the CRT display controller board ( 415-0174-001L) or the CRT driver board at the rear of the CRTs. I do not want to buy replacement boards unnecessarily.
If there are any other tests that you could suggest or perhaps a way to get the text to display in another way so that I can use the machine I would be very grateful.
