shocwav3
- Nov 21, 2013
- Yorktown, Va
As the title states. I do a ton of deep pocket milling in aluminum (usually 5-6" deep) Most of the parts I can add a generous rad on the floor or in the case of 3d surfaces I can usually add a degree of draft to aid in getting down into the cavity.
I am using solid carbide now, primarily Swiftcarb .750 ramp mill, necked with 6" of reach.
But I would really like to move to a modular screw on type with different heads. My thought process is to be more versatile with less tooling. So use a roughing geometry then maybe a copy/button style for 3d profiling, also different gauge length holders so I can shorten up when I don't need all the reach.
The thing I seem to be running into is, all the modular head lines I find seem to be geared towards tougher materials. Do they even make inserts for aluminum?
Dapra has a line of inserted ball mills that accept backdraft, flat, ball and high feed that could also serve the purpose, but the inserts again seem to be gear toward milling or exotics and hard material.
Anyone know of an indexable or modular head line of tooling that would serve my needs?
Thanks in advance
Thanks in advance
