Definition of each lathe axis
Results 1 to 11 of 11
    Jan 2003
    Pacific Northwest
    1,266
    66
    Default Definition of each lathe axis
    I've seen two different versions.
    Spindle axis Z or X
    Cross Slide X or Y
    Is there a standard?
    Jan 2008
    Northeast Ma.
    150
    10
    35
    Default Lathe Axes
    On a lathe it is standard for the Longitudinal to be Z and the Radial to be X. Vectors are I and K
    Jan 2003
    Pacific Northwest
    1,266
    66
    Yes, Z and X are what I've heard the most of in the manual world. So Z and X are the standard in the CNC world, right?
    Dec 2007
    los angeles, ca
    19
    Default The Spindle
    The axis parallel to the spindle axis is always Z, whether its a mill or lathe. And, for the lathe, the axis that controls the diameter is always X.
  5. Likes Getter-Done liked this post
    Nov 2004
    Canada
    1,765
    And the Lathe rotary axis conform to the standard of A rotates around X, B around Y, and C around the Z.
    C is the most common on a Lathe, as it relatively easy to turn the chuck into a C axis.
    M.
    Dec 2007
    Southeastern US
    6,227
    731
    2592
    Quote Originally Posted by laminar-flow View Post
    It's called the "right hand rule". Orient the thumb, index and bird finger of your right hand 90° from each other. Point your thumb along the spindle centerline, in the work area of the machine. Your index finger is X, your bird finger Y and your thumb is Z. All fingers should point positive.
    Axis A, B, C are relative to the three primary axis. A is rotational about the X axis, B is rotational about the Y axis, and C is rotational about the Z axis. (These can also be designated as rx, ry & rz, most notably on robots.)
    Note: This does not _always_ apply, as there are some odd-ball and downright weird machines out there, mostly in specific applications.
    Robots work via the left hand rule. Same deal, but with the left hand and relative to the base, not a spindle.
    Jan 2003
    Pacific Northwest
    1,266
    66
    OK, thanks. I just wanted to clear all of that up.
  9. #8
    Aug 2005
    Bremerton, Wa
    2,595
    66
    68
    I think that would be the left hand rule. I have never seen a machine (lathe) where moving towards the spindle was a positive move.
    On a mill up is positive, an dit would be a left hand rule.
    C rotates about Z
    A rotates about X
    B rotates about Y
    On a lathe moving the tool away from the centerline is positive and moving teh tool away from the spindle is positive.
  10. #9
    May 2007
    Massachusetts
    786
    6
    51
    Okay
    Right hand should work in all cases.
    Right hand, palm up, thumb to right, index away from you, middle finger straight up.
    Thumb is X positive
    Index is Y positive
    Middle is Z positive
    This applies to pen and paper, and milling machines
    Move so that index finger is up. This applies to CAD/CAM systems, where Z plus is coming at you from the screen (default view, mostly.) X (thumb) is still pointed right.
    Turn (contort) so that the index (still Y) is pointed down, middle is pointing right and thumb is towards you. This applies to lathes with the turret working from the operators side of the spindle.
    This is why on these machines, G02 and G03 as well as TNRC seem backwards.
    Contort some more. Index points up, middle points right and thumb points away from you. This applies to lathes that have the turret approaching the work from the side opposite the operator.
    Here, G02 and G03 and TNRC seem correct.
    Haven't had experience on HMC's so I'm not familiar with that configuration, but I'm sure it agrees with convention.
  11. #10
    Nov 2004
    Canada
    1,765
    Quote Originally Posted by beege View Post
    And Oscilloscopes.
    One thing to remember with Mills, the spindle is often fixed in the X/Y so the table moves in the 'opposite' direction to account for this.
    M.
  12. #11
    Jul 2005
    Midlothian, Virginia
    2,610
    70
    222
    The up and down wobble on Chinese hobby-grade lathes is the Y (pronounced "Hwy").
