Hey guys,
I've been using some cheap eBay end mills for the past couple of weeks with varying success. They don't seem to last as long as I had hoped, even though they are they inexpensive kind.
I purchased GWizard awhile back so that I don't have to worry too much about figuring out the proper feed rates, or spindle speeds. The only real question I have is with the depth of cut.
GWizard actually gives you numbers based on your parameters, but I'm wondering if the depth of cut I'm using is even worth it. The deepest cut I've tried with an 1/8" end mill is 0.030. This seems
to go just fine for awhile, and with a brand new end mill, the cut is almost perfect. Depending on the feed rate, I can get a decent finish, but I'm worried that I'm digging into the material too deep and wearing
out the end mill too fast. The numbers I'm going with are - (17ipm feed rate / 15400RPM spindle speed / 0.030 DOC)
Is that depth fairly common? Should I be trusting GWizard's parameters when I enter in my depth of cut?
I should point out that my biggest problem right now is heat. I have a dedicated air blasting line that directs air right onto the end mill, but I currently use a dust boot that's trapping the heat from the router + end mill. I'm
using this dust boot to keep the chips from going all over the room. Unfortunately, I don't have a dust collection machine yet (it's on order), so I can't really tell if this will remove enough of the heat. I'll know more about
that in the next week or so. The opening for the dust collection is plugged up with some paper towels, just to keep the chips from blasting out the top. This will all be corrected later, once the dust collection machine arrives.
I'm cutting aluminum. I should have specified this above. My apologies.
