The difference between machining accuracy and positioning accuracy - Page 2
Results 21 to 40 of 41
  1. #21
    Aug 2006
    Wisconsin
    1,506
    639
    567
    I meant to say three to five microns. .003-.005mm in my first post.
  2. #22
    Jun 2017
    Illinois
    33
    Quote Originally Posted by 5 axis Fidia guy View Post
    This will be an interesting read. I will tell you this. We just purchased a Hermle, C42 5x machine. The utmost in positioning accuracy. When I check the kenematics with the ball over the entire 800mm range of travel, I get an error or around .003-.005 microns, very impressive to say the least. BUT, trying to do a simultanious cut and hold tight tolerances, that is another story. Machining accuracy consists of, programming software, toolpath tolerance, tool tolerance, holder accuracy, shop temperature, tool runout, the list goes on and on. Take a ball endmill with a .0004 tolerance, then add a .0002 toolpath tolerance, then add holder runout of .0001 or so, now the tool is hanging out a way and you have some deflection, the material is heat treated so add some more deflection, now warm up the spindle of the machine a while, now the shop heats up.. you are out .0005-.0006 before you even hit a button. IF I am very, very careful, I can hit a .0005 range, +-.00025. But that is taking everything into account. To just set up a tool, run it thru the laser and hit the button, maybe .0007 if your lucky. And this is with premium tolerance tooling.
    I am very curious as to how 5 axis fidia guy is checking across that 800mm.....I don't believe it, SORRY!? I've been around Moore Nanotecnology, Precitech and Toyoda machines turning lens and other components using diamond tools, and I don't believe that .003/.005 micron for a millisecond.
    That machine, and any other 5-Axis is not as accurate producing a "machined". The 5 axis trunion with rotary only adds to amount of variables that make for lost tolerances. I was at a customer in Texas who had a Hermle, and was told that they dont use tooling over 1" cutting the turbines/impellers....the 1.500" tool I gave them ran 3 minutes because of the lack of rigidity and material they were cutting offered a large amount of resistance and deflection. What the spec's say and what you get are two different things.
    Now the rest of his information regarding the tool, holder material and other variables do stand up to what you will get when you machine something.
    It's like saying this reamer has a +.0002/-0.0 tolerance, but getting that to repeat in the machine, on the material you have is another story.....I've met dozens of people who never ever have indicated a reamer in a holder or used a floating holder to help with that.
    OOOOHHHHHH, 3-5 microns....that I think I can believe, not .003-.005 microns. I didn't read on to see that one!!!!
    LOL!!!!!
  3. #23
    Jun 2017
    Illinois
    33
    any machine will move the .0001" it says in the manual, and And being the skeptic I am, I don't believe the control on the machine to "eliminate" the backlash or error in its movement is going to be as accurate as a third party system used to measure it.
  4. #24
    Nov 2013
    Utah
    2,443
    673
    1299
    For the sake of the advertisement they are meant contextually as the same thing. Positioning would be the ability to travel away from a point and return to that same point, basically. Using "Machining accuracy" as a hot word or flash word--to sell machinery. As it were, "Positioning accuracy" and "Machine accuracy" being seperate would be redundant, let alone stupid.
    Like saying "if it's not making chips it repeats really good, but when your in the cut then repetition falls of $#^%*R^&" Dumb.
    R
    ON EDIT, The actual sales pitch would be the "positioning accuracy" not the "Machining accuracy" same point though.
  5. #25
    May 2007
    Central Texas, West and North of Austin
    1,628
    178
    523
    I have NOTHING to add. This has been one of the more educational threads I have followed, and has reinforced my opinion that ,even after 35+ years in this, there is a whole lotta stuff regarding it that I do not know yet. And why I follow threads that I know very little about on this Forum. I genuflect at the feet of some very smart sumbitches here abouts. You guys amaze me.
  6. #26
    Mar 2011
    NY USA
    800
    155
    509
    One of my nerdy habits is calling up the thermal comp screen on the Okuma and watching as the control actively comps out thermal growth in the various parts of the machine that it monitors. It's neat to watch it change things by parts of a micron. I didn't really know if it worked or if it was just something shiny for nerds like me to watch, but this past week I had to shoot some shallow bores in aluminum, half thou tolerance so I calibrated up the fancy bore gage and 100% checked them. Granted 6061 isn't exactly hard work for a 560 but I was floored by the consistency. The digital bore gage calibrated to a master ring, has a resolution of .00005" and it never changed. Now maybe those interpolated bores were wandering for the 50 millionths and the gage wasn't showing it..or maybe they weren't but still...1.3 micron over a 5 hour run at aluminum feeds and speeds is pretty damn impressive. This is only 3 ax, so I get that 5ax is exponentially harder to pull off but it's pretty amazing what they can do with real machining accuracy these days.
  7. #27
    May 2014
    Ann Arbor, MI
    5
    Somewhat OT, but what the heck...
    The ATLAS experiment at the Large Hadron Collider is about the size of my house, and there are many, many thousands of fine wires in the detectors that track the paths of the collision products. To turn the raw data into useful information they need to know the position of every wire to within something like 20 microns. There are lasers and retroreflectors all of the instrument so they can measure everything interferometrically - they don't just worry about thermal expansion, but also tidal effects. I doubt that any 5-axis machines pay attention to the phase of the moon...
  8. #28
    May 2009
    Wyoming
    2,984
    6510
    4567
    A given machine today will very likely repeat position to within .0001, but that's only half the battle. Imagine a half-inch end mill pocketing 3 inches deep. How square is the wall going to be, assuming you don't have time to sneak up on it for two hours? The results in a case like that simply cannot be guaranteed and have a lot more to do with operator experience and the stiffness of the tool and setup than the accuracy of the ballscrews...
  9. #29
    Nov 2013
    Utah
    2,443
    673
    1299
    Quote Originally Posted by khillig View Post
    OT?? meaning Other Team? Or maybe O.S.--Other Sport
  10. #30
    Oct 2013
    Rochester, NY, USA
    103
    30
    It sounds like they really mean:
    Positioning repeatability
    and
    Position accuracy
    The stage may move and come back to the same position within 0.0001" (repeatability) but may travel crooked or curved so the accuracy (of the expected straight line travel) is much worse.
  11. #31
    Feb 2004
    Napa, CA
    2,587
    43
    682
    Quote Originally Posted by john-san View Post
    On machines with direct position measurement (like most Hermle) the position will be as accurate at the measurement system, which can be much better than 0.0001". Even if the belts are loose and the screws are screwed. The position servo loop will compensate.
    Quote Originally Posted by greif1 View Post
    and
    Position accuracy
    Interpolation accuracy or motion accuracy is a whole different thing from either position accuracy or repeatability. The latter two are typically measured statically, the former dynamically. A ball bar test does measure interpolation accuracy for some circumstances. Interpolation accuracy depends on matching the dynamics of motion between the axis exactly, or moving so slowly that the position servo loop can compensate for mismatched dynamics.
  12. #32
    Feb 2017
    Tennessee
    6
    No idea who that is. But I will take a picture of it next time I do it.
    picture it in a machining cycle with tooling//.
  13. #33
    Nov 2013
    Utah
    2,443
    673
    1299
    Quote Originally Posted by one horse View Post
    ?? Gmatov in a Machining cycle? That would be interesting, most cycles are too new to match that personality. Maybe the wrong cycle, like using G84 before G83, very explosive.
    R
  14. #34
    Sep 2012
    SWEDEN
    64
    22
    16
    Good question.
    I have driven machines with machine accuracy claimed around or less than 0.0002'' (0.005mm) when new, and been running parts around that tolerance. Good all the time? nope! Timing, pace of working, not talk about temperature, day of time, or tools wear out, etc made measurements go just mad. The tolerances I had to do was just that, 0.005mm. 30% of the workpieces was scrap, but still it was manageable and somewhat doable. Me sux? I buy that too.
    So from my point of view the machine was able to do (my best guess) half of claimed 'machine accuracy'. So conclusion machining accuracy and machine repeateably is NOT the same thing. I have a good advice tho. Dont go there, that land of precision is evil. Even a bad look makes it go haywire and kick your butt sore. =)
  15. #35
    Jan 2011
    telford, pa
    353
    31
    102
    Okuma!! Repeat all day long!
  16. #36
    May 2005
    CA
    931
    163
    I don't believe there is much new in physics (which is ultimately what determines how consistently and accurately a parts can be machined).
    Spindle length comp for temp
    Coolant temperature
    Shop temperature
    Overall machine temperature (Mikrons will run 3 chillers -- coolant, spindle, and ways (linear drives)
    Stiffness of holder
    Runout of holder (*everything* has runout)
    Stiffness of spindle
    Stiffness of cutting tool
    Or how about the natural frequency of each of those pieces... is there any undesirable "stacking" of harmonics?
    etc. The list goes on and on...
    And then finally... on a particular machine (whether a Bridgeport, an Okuma, a Haas, or in this case a C-42): how far is it from the part... ALL THE WAY back around to the cutting tool? e.g. on a C-42: Part, to table, through C-axis, through B-axis trunnion, into the main casting of the machine (much of it "poured" on a Hermle), then through the guideways for the X axis and Y axis, through the guideways of the Z axis, then through all the bearings and back down the spindle to the cutting tool. It's a *long* ways from part to cutter! (though possibly a shorter distance and stiffer on a Hermle than most any other 5x machine of the same capacity).
    The fact that these machines can even *position* (much less cut!) to microns is just amazing.
    PM
  17. #37
    Jul 2015
    North Carolina
    67
    15
    16
    I think it's unambiguous in this context, but I don't doubt their are people available to misunderstand it. What's the machine do? It machines. How? By positioning itself. Since there is a direct relationship between machine positioning and machining accuracy I think the claim is sound.
    However, I did have a supervisor that ran everything in metric because he thought the positioning was more accurate. I disagreed; I think the higher resolution of the adjustments allowed the operator to be more "accurate", but the machine was most likely indifferent to SAE vs Metric.
    He also took a manufactures claim that a certain end mill could be used for roughing and finishing and eliminated the finishing tool we were using. And basically ended up going through a lot of tooling unnecessarily because the accuracy suffered quickly from tool wear.
    2 cents.
  18. #38
    Nov 2013
    Utah
    2,443
    673
    1299
    Quote Originally Posted by Cheshire View Post
    Ever considered, not saying what you think it may not mean, or don't mean in double negatives?
    R
  19. Likes Cheshire liked this post
  20. #39
    Jul 2015
    North Carolina
    67
    15
    16
    R
    I haven't not done that or not.
  21. Likes litlerob1 liked this post
  22. #40
    Jan 2003
    Pacific Northwest
    1,266
    66
    My Haas TM1 has small issues. When the spindle heats up, the Y grows - and the Z grows down. When new it was about -.0005 in Y and -.0008 in Z. Now that the spindle has (moved the grease to where it does not heat up as much?), these numbers are much less. There is a little wobble in X when moving in Y, about .0001. I notice this on the sides of a surface. A slightly bent Y screw? This is only noticeable when a Y surface is swiped on a surface plate and examined as it matches the pitch of the Y screw.
    Still like the TM1.
