Hi all.
Good day everyone.
I am new here & this is my first post.
I am sorry if someone has already posted this question which I am going to ask, I didn't find it.
I am using CNC Turning Centre with Fanuc Oi-Mate TD series.
The problem I am facing is about different finishes I am getting with same program, same material, same component.
I am making a component out of 28mm round bar of Mild steel(low carbon steel) material, in which drilling is done of 21.5mm & i have to bore it to 23.30mm final size. When making this component I am getting different finishes like sometimes superfine finish, sometimes fine finish with some lines & sometimes chatter. I tried almost everything like increasing/decreasing speeds & feeds, clamping pressure of chuck, changing inserts, flow of coolant but unable to find the solution to unwanted noise & different finish.
If anybody came across this problem & have solution to it, please help.
Details of component:
Bar Dia: 28mm
Bar length: 67mm
Bar length hanging out of chuck: 15mm
Drilling : 21.5mm
Boring: from 21.5-23.00mm
Final cut: 23.30mm (also increased/decreased the DOC)
Bore length: 45-46mm
Boring Insert CCMT09, nose radius: 0.4
Boring Bar Dia: 16mm
Boring bar hanging out of turret: 52mm
Any kind of help will be highly appreciated.
Kusshal
Good day everyone.
Bar Dia: 28mm
Bar length: 67mm
Drilling : 21.5mm
Kusshal
