Different machining time for same NC Code.. reasons?
Page 1 of 2 12 LastLast
Results 1 to 20 of 23
    Aug 2017
    UNITED KINGDOM
    6
    7
    Default Different machining time for same NC Code.. reasons?
    Hi all,
    I've carried the experimental tests (using the same NC code and set up) in two different machines (Haas TM1P & Haas VF3) and the machining time was completely different, nearly 2x slower on the TM1P.
    The basic specifications of the machines are:
    TM1P: 7.5HP and belt drive spindle
    VF3: 30HP and inline direct drive
    Would you know more reasons on why such difference in the machining time? Any insight is valuable..
    Thanks in advance
    Sep 2015
    Ohio
    646
    364
    649
    Tool change time, rapids
  3. Likes digger doug, lcmRES liked this post
    Mar 2017
    CHINA
    1,994
    924
    Quote Originally Posted by lcmRES View Post
    Had a friend with a late model something-or-other and an elderly ExCell-O 104 with Gettys drives (DC). Put the job from the newer machine onto the ancient old-technology ExCell-O, parts went about 30% faster
    Them Gettys drives, if sized correctly, can shit-n-git. Lots of acceleration, even with slower top speed, ended up cutting cycle time.
  5. Likes digger doug, lcmRES liked this post
  6. #4
    Jun 2007
    Garland TX
    353
    137
    87
    TM1P (short for tooling mill) doesn't have nearly the RPMs available as the VF3. Depending on how your program is written with a slower RPM comes a slower federate. If memory serves me the rapids aren't near as fast either as Booze Daily said. Tool changes. I believe the VF stages a tool to be ready for the change and the tooling mill doesn't, after putting the tool away it turns the carrousel to load the next one. Quite a bit slower
  7. Likes lcmRES liked this post
  8. #5
    Feb 2013
    Madison, WI
    585
    807
    333
    Tool change time, rapids, spindle and axial acceleration and deceleration. There's other settings and parameters that can have adverse affect as well.
  9. Likes G00 Proto, sfriedberg, lcmRES liked this post
  10. #6
    Aug 2016
    ALAND ISLANDS
    1,393
    43
    96
    if i may : tick-tock timer is not tests
  11. Likes digger doug liked this post
  12. #7
    Feb 2013
    Northern Mn
    355
    77
    386
    Quote Originally Posted by AARONT View Post
    This is it exactly. Even with identical code, the TM series is going to be much slower than the VF series, even on a program with no toolchanges. The VF series have much higher torque servos and can Accelerate and Decelerate much faster. The same goes for the spindle. Because of the higher horsepower with nearly equal rotating mass, the VF can bring the spindle up to rpm and stop the spindle much faster.
    There is an interesting youtube video of a VF2, VF2SS and a DM2 running the same code, same feeds and speeds.
  13. Likes lcmRES liked this post
  14. #8
    Mar 2017
    CHINA
    1,994
    924
    Quote Originally Posted by G00 Proto View Post
    I'd be interested to see a comparison of a late-model Haas with a 1980 104 ExCellO
  15. Likes lcmRES liked this post
  16. #9
    Oct 2005
    erie,pa
    8,417
    15299
    4116
    Quote Originally Posted by SeaMoss View Post
    Especially when you can get rid of 3/4 of the roughing cuts
    with the Excello.....
  17. Likes sfriedberg liked this post
  18. #10
    Mar 2017
    CHINA
    1,994
    924
    Since it looks like there's at least one other ExCellO fan here, gotta share ...
    Went to a show some time around 1980. The baby ExCellO was brand new, that was one of the machines I really wanted to see. Typical show of the time, the Anilam guys were waltzing around in their wizards costumes, the US Machine Tool guys had the bikini babes laid out on the tables, and over on the edge (I forget who the distributor was but it's an old name) was the ExCellO. But the thing was brand new, they didn't have a spare, Grove Valve had pre-paid and needed to run parts, so here was this little ExCellO, surrounded by flash and bling booths, with a greasy-ass guy in overalls loading cast iron valve bodies into it and running production. It was running Trim-Sol and making a mess
    Same show had a RAM 630 wailing away on steel. Sounded like someone with a B.A.R. going crazy inside the enclosure. You could put your hand on it and not even feel any vibrations.
    @ ewsley - American machine tools were good. Not all of them, but the good ones were spectacular. The Japs are kinda-sorta-maybe catching up now, decades later. If only the electronics had been reliable ...
  19. Likes lcmRES, digger doug liked this post
  20. #11
    Aug 2017
    UNITED KINGDOM
    6
    7
    Tool change time was more or less similar, even a bit faster on the slower machine. The rapids hold the same reference value on both..
  21. #12
    Aug 2017
    UNITED KINGDOM
    6
    7
    Quote Originally Posted by conceptdevelopers View Post
    The RPM set in the code was based on the TM1P max. The observed tool-to-tool average time was quite similar for both machines (surprisingly slightly faster on the TM1P).
    That's the machining power profiles of both cutting processes in which you can see the tool changes:
  22. #13
    Aug 2017
    UNITED KINGDOM
    6
    7
    This these are the keywords 'spindle and axial acceleration and deceleration'.. the differences on the transient state of each machine.
  23. #14
    Aug 2017
    UNITED KINGDOM
    6
    7
    Quote Originally Posted by deadlykitten View Post
    Hi, I should've told more about the experiments before, my apologies. I'm monitoring the power consumption of the cutting process on each machine. However, my measuring frequency wasn't large enough to catch the transient states in details, but can ensure tool change isn't the issue. I've attached the power profiles I got for each machine and the power distribution for machine VF3 so you may see better about the process. Thnx, Lorena
  24. #15
    Aug 2017
    UNITED KINGDOM
    6
    7
    Thank you. Would you know more about the mechanical time constant of those machines' servomotors?
  25. #16
    Aug 2016
    ALAND ISLANDS
    1,393
    43
    96
    pls share a better quality of those images, and pls share from where you got them
    i suggest WeTransfer
    just send the files to your own e-mail, and paste the link here
  26. #17
    Jun 2004
    Melbourne Australia
    5,014
    643
    1834
    Good God, tell me your not in a thread where acell / decell matters,
  27. Likes litlerob1, Mtndew liked this post
  28. #18
    Jan 2015
    459
    76
    231
    Quote Originally Posted by machtool View Post
    Unfortunately, his verbal diarrhea has infected every thread in CNC Machining.
  29. #19
    Aug 2016
    ALAND ISLANDS
    1,393
    43
    96
    hello again as long as cncs are not identical, also machining durations will not be equal
    please consider that identical cncs may be tuned differently, so to deliver different durations on same code
    why do you bother with such differences ? whats the goal ?
    even if it seems relevant, actually you should not reffer to that diagram, but to specific code paragraphs
    for example, to compare rapids, simply run a program with many rapid movements
    to compare spindle, simply run a program that will acc and decc the spindle
    same for feed, etc ...
    but in the end, whats the goal ? you will have the time differences, and after ?
    if you wanna push things, try to tune your cnc ... unfortunately, i can not help you with tuning specifics for haas
    few dare tuning servos, etc, and most are comfortable with the way the cnc works
    if it works, dont touch it ...
    i dont know what you are after : understanding the basics, or pushing the cnc ?
  30. #20
    Nov 2013
    north of Bean town
    342
    45
    89
    could it be different parameters for say a drillig cycle?
    I have a mycenter with yasnac control and an okuma with osp...
    when drilling with g83 the cycle times are completly different using the same program
    but if i switch the g83 to g73 in the okuma the times are right in line with eachother
