Different machining time for same NC Code.. reasons? - Page 2
Community On The Web
Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
  1. #21
    Aug 2016
    ALAND ISLANDS
    1,393
    43
    96
    hy / maybe you should check the ipw settings and d values, so to speed up the drilling cycle for the okuma
    generally i use long hand drilling codes, because of situations when cycles could not deliver
  2. #22
    Jan 2007
    Flushing/Flint, Michigan
    5,875
    226
    4734
    Quote Originally Posted by deadlykitten View Post
    if you wanna push things, try to tune your cnc ... unfortunately, i can not help you with tuning specifics for haas
    few dare tuning servos, etc, and most are comfortable with the way the cnc works
    I don't see how tuning affects cycle time.
    The trajectory planner could give a poop if the servo follows it or not and it is the guy that controls cycle time.
    Certainly tuning affects how good the cut and your following error is but the control won't slow down for a slow servo loop unless you trip the limits and it stops.
    Have you made a machine cycle faster just by tightening up the servo loop gains?
    Bob
  3. #23
    Aug 2016
    ALAND ISLANDS
    1,393
    43
    96
    hey bob
    here are some posibilities :
    ... editing acceleration + ipw
    ... improving transition between feed movements
    ... interpolation on entire toolpath
    i have messed with values that delivered different time for same toolpath, or make the cnc motion more smooth
    what i dont like is that some parameters can not be changed from code
    onestly, i did not comprehend such functionalities the 1st time i saw them and i owe a lot to veterans
    in the thread about robodrill slowing down near corners, you said that there must be a method to make the control behave old-school i have tried to do the same on a newer control, and i was told to let it go, because increased diff error is equivalent to increased tirr, and speeding arround does not have good effects
