As I understand it 0 is disabled.
David
Have you looked at all the paperwork inside the electrical panel to see if there is a note explaining what to do? Have you looked in the electrical drawing to see if there is a note?.
I can inform of what I think you have to do but you will need dummy plugs which I guess you have also lost?. = I cannot help you.
*You must be very careful when changing parameters.
I have a manual for MC600VF 1992 and a manual for MC600VF 1994.... the parameter for 4th/5th axis enable are different....
1). Parameter to turn of the Matsuura PLC lines related to the 4th axis...I strongly suspect your machine will be 1994 spec..
In the 1992 manual 4th axis ON = 7001 bit 0
In the 1992 manual 4th axis ON = 7001 bit 2
In the 1994 manual 4th axis ON = 7080 bit 6
In the 1994 manual 5th axis ON = 7080 bit 7
2. ). PM 4022 bit 3 sets if the 4th axis has to be referenced before cycle start is allowed. Set this to 0 = no 4th axis
PM 4022 bit 4 sets if the 5th axis has to be referenced before cycle start is allowed. Set this to 0 = no 5th axis
3). Now you should be able to fit the dummy plugs to the encoders to stop the servo alarm and over-travel for the tilt axis. I guess you have lost these plugs?.
You would need 3 plugs ......1 for the 4th axis encoder / 1 for the 5th axis encoder and 1 for the 4th axis bigger plug which ha the motor power connection / A link to override the over-travel 'estop' signals is included in this plug.......
*Check you electrical drawings....some machine has 4th 5th wiring drawings that showed the connections of the dummy plugs....
Yes I was referencing page 298 of the Yasnac parameter manual you show. I did check the cabinet for a switch but see nothing. I followed the cables from the 4th to the drive. I haven't opened the box yet where the 4th axis cables connect to the machine on top of the machine to check there.
I forgot about the dummy plugs. I don't have them and doubt they were ever made. Is there any chance of removing the 4th without the dummy plugs?
Notice
