NAST555
Stainless
- May 23, 2008
- Gauteng, South Africa
So I was abot 5 metres away and heard a crash and the operator hitting the feed hold. Go over to look and he is staring at the door. I think the poor guy needs a pants change now. A 15mm drill decided to break off right where it comes out of a collet when it made a rapid move out the hole Anyways so if you look at the pic you can see the bottom left corner where it hit the glass.
What glass is used for this? I obviously need to replace it. It is some form of shatterproof glass because not one single piece of glass, at least from what I can see, is loose or broken off.
