Hi,
I have been researching on various bugdet VMC's that can do good job for our toolroom where we make compression & Injection moulds on SS & P20 type materials.
Over the past four months with the help of this forum we have come across various machines such as Makino PS, Okuma Genos , YCM NXV , Hardinge GX, DMG MORI CMX , Hwacheon Vesta & Doosan DNM.
Probably, Okuma does stand out the most. If our finances allow we will go for Okuma Genos 560V. However, in case finances doesn't then we shall have to find our next choice. We have to choose between YCM NXV or Doosan DNM 5700
Both machines are on Roller bearing, 12K Spindle RPM & Fanuc Oi controller with 400 look ahead.
The main differences are as follows-
- YCM spindle lubrication is Air-oil mist & Doosan uses Greese Lubrication.
- YCM is offering more power on axis motor. YCM 3 KW on x & Y axis & Doosan 1.8 KW on X & Y axis
-YCM is offering 15K RPM as option. With Doosam max possible is 12K RPM.
- Doosam machine weight is 6500 kg whereas YCM - 5500 kg
Your expert opinions will help us in finalising our VMC. Looking forward to hear from users.
Thanks a lot.
Thanks a lot.
