GT Performance
- Apr 3, 2018
Good Morning All,
We have an issue on our late model Doosan Lynx with the c-axis milling. The part being machined has an internal 1.6875-18 thread .350" deep. Small thread bar we had was flexing too much but we had a thread mill on hand so I programmed a thread milling cycle to mill it live horizontally. Now the problem is that the threads are not concentric with the bore, they are off .008 TIR from the bore (minor diameter). Is this just a matter of comp in x and or y in the tool wear page or is there a parameter that needs to be adjusted? We indicated all tools in the turret with round holders parallel with the spindle bore and they are all off the same amount (.016" Y and .004 X I believe). We've not had to use c-axis to create something that needed to be concentric yet so this is a first for me. If all else fails we will order a beefier threading insert holder and turn the threads again but the c-axis needs to be solved for future work.
Thanks everybody and anybody!
