Dave K
- Mar 21, 2004
- Waukesha, WI
Ok, I give up. Trying to find a convenient but effective way to line the inside of the draw tube on a Haas Lathe. Here's what Ive tried so far. A lite press fit with plastic bushings tapped into the draw tube. One near the front, and one near the back. Works pretty good but when the spindle is warm and you want to change them, they have expanded a little too much and are a beast to pound out of there.
Next idea was a plastic bushing that is a slip fit but cut a O ring groove in it. The O ring creates a drag on the I.D. of the draw tube to help it stay in place. Problem: Certain areas of the draw tube have a gap for it to draw in and out for closing and opening the chuck. The O rings get stuck in the gap and once again, a beast to pound out.
Third Idea: An aluminum sleeve turned to a slip fit for the draw tube. Aluminum sleeve has a plunger type set screw in it that makes the spring loaded plunger put pressure on the bar. Only need one sleeve that goes on the end of the bar and follows the bar all the way through to the front of the collet. Problem: the plunger does not put enough pressure on the bar, and falls off the bar half the time.
There has to be some good ideas out there for this. You guys got any?
