Drill size for form taps
Page 1 of 2 12 LastLast
Results 1 to 20 of 28
    Aug 2008
    Rotherham, UK
    490
    11
    53
    Default Drill size for form taps
    Never used a form tap before, but I've got a job that would benefit from them so have ordered a dozen OSG taps, as my existing suppliers don't stock forming taps, 1/2-20 UNF, what size drill should I be using with these, as the initial hole needs to be larger IIRC, and I don't have an OSG catalogue.
    Cheers.
    Aug 2002
    West Unity, Ohio
    23,202
    3503
    6475
    Default From the OSG poster on the subject
    #1
    I am Ox and I approve this here post!
    Aug 2008
    Gilroy Ca
    40
    9
    #1
    #1 is for a 1/4-20
    1/2-20= 75% thread .475 65% = .477 55% = .480.
    Mar 2006
    Tennessee
    2,003
    249
    363
    go to WWW.balax.com and download there thread former pdf file. the sizes are also in your machinist bible.
    Aug 2008
    Rotherham, UK
    490
    11
    53
    What machinists bible?
    12.1mm looks spot on for the thread engagment I'm after, and easy to get hold of over here, thanks for the help.
    Aug 2002
    West Unity, Ohio
    23,202
    3503
    6475
    Quote Originally Posted by allez View Post
    #1 is for a 1/4-20
    Yes it is!
    That's what I thought I read.
    It's still Monday Morn here....
    For 1/2-20 their chart reads 31/64ths.
    But just making the hole to the pitch D or slightly larger is really the name of the game enyway... And a decimal reamer may be a good idea to make good and repeatable threads...
    Sorry for that.
    Ox
    Mar 2006
    Tennessee
    2,003
    249
    363
    Machinist bible = Machinist hand book
    Aug 2008
    Rotherham, UK
    490
    11
    53
    Yep, like I said, don't have one!
    Normally I just calculate what size I need but I wasn't sure how to do it for a form tap.
    Jan 2008
    Sacramento CA
    601
    Default Machinery's Handbook
    My book says 0.4531 (29/64") or (11.501mm) for a 75% of full thread. Of course my handbook is a 1943 12th edition -- maybe things are different now.
    Assuming 75% is what you want then I would follow the book.
    Last edited by ietech; 10-06-2008 at 12:31 PM. Reason: Corrected transposed numbers.
    Aug 2008
    Rotherham, UK
    490
    11
    53
    Hmm, sounds far too loose for a rolled thread?
  11. #11
    Jan 2008
    Sacramento CA
    601
    Default I'm not sure
    Quote Originally Posted by PhillipM View Post
    I have never used a (roll) form tap and have been on Google now for a while and really don't find anything but advertising for tap dancing and also some pictures of roll form taps.
    There is an obvious difference so I will continue to find more info -- the process, speeds and feeds, and size requirements may be of significant importance. I just not sure.
  12. #12
    Jan 2008
    Sacramento CA
    601
    Default Old handbook again
    MHB says the diameter of the blank for 1/4" thru 1/2" should be 0.002" to 0.003" less than the pitch diameter.
    Major dia for 1/2"-20= 0.5000
    Pitch dia. = 0.4675"
    Minor diameter = 0.4350"
    So 0.4675-0.003 = 0.4645 Slightly larger than the 29/64" I said earlier. So the options based on this are: 29/64" (0.4531), or 15/32" (0.4688), Maybe reaming the 29/64" to size would work.
    I'm gonna have to do this at least once just to say I tried it. Not much call for it in my world tho.
  13. #13
    Aug 2008
    Rotherham, UK
    490
    11
    53
    I'll let you know after I've broken half the taps
  14. #14
    Jan 2008
    Sacramento CA
    601
    Default Let us know
    Please let us know what you come up with I am very interested in learning about something I have never done.
  15. #15
    Aug 2002
    West Unity, Ohio
    23,202
    3503
    6475
    Quote Originally Posted by ietech View Post
    I think your gunna have a very bad first time experioence running those numbers.
    I like to generally run my holes a bit tighter than recommended, But I don't think I ever end up with a start hole SMALLER than PD. I recommend that you re-think that.
    I am Ox and I approve this post!
  16. #16
    Mar 2003
    Utah
    1,057
    51
    15
    Machinery's Handbook recommends working to 50, 55, and 60% full thread for form taps. Just like this chart:
    http://www.championscrew.com/form_tap_drill.htm
  17. #17
    Jan 2008
    Sacramento CA
    601
    Default I will be trying
    I'm gonna try it as soon as I can and be assured I will follow your advise -- I respect the fact that you have sucessfully done this before so I will start with your numbers and work back to my calculations just for fun -- Thanks this is an interesting thread.
  18. #18
    Jan 2008
    Sacramento CA
    601
    Default Good Link
    Quote Originally Posted by apestate View Post
    Thanks for the link to the chart I will be saving it in my favorites.
  19. #19
    Aug 2008
    Gilroy Ca
    40
    9
    #1 is for a 1/4-20
    This info i posted is from the Balax book.
  20. #20
    Mar 2007
    Aylesbury, U.K.
    232
    11
    What material are you tapping; it makes a difference as there is some 'springback' when using form taps. Aluminium is quite soft so it forms quite well. Stainless OTOH will spring back a little so a larger drill is needed for tougher materials. Remember that you can only form tap ductile materials so cast iron is a no-no.
    Form taps are actually made to a 6HX tolerance which is larger than a 6H; this is to factor in the springback.
    You had best do some testing and use the largest drill that will still give you a good thread; these taps use a lot more power than a cutting tap and you should run them faster as well.
    I usually check with a go/no go gauge to allow me to use the largest drill possible while staying within tolerance. You will break less taps and have longer tool life the bigger you drill.
    I am also an advocate of ER tapping collets; they have a square in the bore to hold the tap securely They are expensive but since starting to use them we have never broken a tap. Just a few degrees of slippage in a collet will put enough strain on the tap to break it. WNT have them.
    I know you were just asking for drill sizes but I hope the above info. is of some use.
    I assume that you are rigid tapping in a VMC...
    Regards,
    Mike.
