Teps71
- Aug 4, 2003
- Sidney, OH
I have a Milltronics Cent 6 which is compatible with Fanuc. The question I have is, is there a way to setup a macro for facing off parts to length. In other words, I have stock which I saw cut to ~ 0.050" oversize. Then I face the ends to length, first facing .025" off one end, then .025" off the other. What I would like to do is edge find my work stop, then move over the desired length plus half the tool diameter. Then add another .010" to sneak up to the exact length, measuring the part and adjusting the Zero. Zero would be in the middle of the part on Y. The macro would allow the operator to input the width of the part on Y. Everything is accomplished in 2-axis mode.
Is it possible to do this in G-Code? Currently I write programs in conversational and have a program for each size of stock.
