Drilling 316L
Results 1 to 2 of 2
Thread: Drilling 316L
    Jan 2013
    Maryland
    39
    Default Drilling 316L
    Looking for some advice on drilling
    316L. Setting a job on a Citizen M20.
    The part is pretty simple. It’s .409 long .208 dia. x .345 long then .300
    dia. 165 long.
    It has a .136 thru hole. I’ve tried both HSS and Carbide drills neither were coolant thru so I cound only use high pressure line and on od of the drill. Both ran around 100 parts before breaking.
    I have some carbide coolant thru drills coming in tomorrow. Cycle time is 50 seconds and I have 60,000 of them to run. So one second equals about 16.5 hours .
    Jul 2008
    Milverton, Ontario, Canada
    404
    82
    140
    Do not peck. Youre going 5xd with a carbide CT drill. Should be good to go!
    Make sure you do not spot drill for the carbide drill. A nice flat face is all that is needed, Make sure machine alignment is tits.
  3. Likes rkrolak10 liked this post
