I'm machining some PVC right now too... ***** WARNING **** total cluster fuckaroo of a setup pic below.
Once a year or so I have a repeat job with the gray stuff. Its an easy one to work with. Its not quite Delrin
But its not Teflon or UHMW
... This white hardware store pipe seems quite a bit harder than the gray stuff I've worked with.
Feed it HARD. Maybe 0.02-0.03" per rev.
THAT ^^^^^
Though I would honestly suggest feeding HARDER.. I've fed .060 a rev with a 5/16 in UHMW
(I HATE that stuff) and
I'm running some HDPE in the mill right now and feeding .040 a rev on a 1". And I KNOW I can go harder... Give me a sec....
At 250sfm (1000rpms).. She's fine at .100 a rev... Parts done. I'm going to try .150 a rev.. Going through 1" thick, no
peck..
.150 was FINE... Hang on again...
.200".. It did it, but it pushed up some burrs. I'm pretty sure I over ran the relief angle of the drill..
Here is .200 a rev, kind of ugly, its actually tossing a burr.
And here is my cluster fuckaroo... Parting off hardware store PVC pipe. Shooting for as few burrs as possible.
5/8" spacers. Running 7 at a whack, takes about a minute. Running dry so I don't have to wash 'em.
Back to the OP.. Just PUNCH IT.. Take what you would feed the same drill in a mild steel and multiply X 10.
Slow SPeed, and pile drive it. Just don't out run the relief.
