Hello Everyone,
I need to ask question about drilling operations which follow each other,
I have a workpiece which's length is around 250 mm. and and i need to drill from its back side but the problem is different diameter drills needs to work(dia=4,dia=5,dia=6,=dia=7,dia=8,dia=9,dia=10,dia=11,dia=12) in same center.If i start drilling operation from dia=12.After dia=10 or dia=11, i can't find enough lenth center drill for other diameters, and if i continue drilling operation without center drill.At the end i have a hole which is eccentric from center.
If i start drilling operation from small diameter(dia=4) and continue without center drill. The result doesn't change , i have a hole which is eccentric again.
So is there any advice regarding this issue or is anyone encounter this kind of process, if it is "yes" please share your experience with me.
