Home Page Forums Articles Videos Search Register Advertise
Go Back   Practical Machinist - Largest Manufacturing Technology Forum on the Web > Manufacturing Today > CNC Machining
CNC Machining Discuss CNC machines, programing, troubleshooting, retrofits.
Reply
LinkBack Thread Tools Display Modes
  #1 (permalink)
Old 03-12-2010, 01:13 PM
Default drip into a fanuc o-mate
Has anyone ever drip feed on a fanuc o-mate m control? It doesn't have a remote button. I have been told you can drip feed on it. All I can do is send and recieve into the memory.
Dwayne
  #2 (permalink)
Old 03-12-2010, 01:46 PM
Stainless
From what I've read on 0 controls, the RS232 connection was an option. Look for a PM.
  #3 (permalink)
Old 03-12-2010, 02:09 PM
Stainless
In some cases an external switch has to be connected to a PMC input to set register G127.5 to 1. and the mode switch set to AUTO
IOW it may need a ladder change/addition for this.
Tried including a pdf but only allows small files?
Minder.
  #4 (permalink)
Old 03-12-2010, 08:30 PM
PixMan's Avatar
Stainless
You could always just call Methods Machine Tool's service department and ask. They've been really kind abut helping out with things like that.
978-443-5388
  #5 (permalink)
Old 03-13-2010, 05:22 AM
Titanium
Quote:
Dwayne
Does the main mode switch have a 'tape' function?
Can you go into the operators panel showing the various mode switches (single block, dry run etc) and it shows a DNC option?
If not, then it has to be turned on via the register switch
  #6 (permalink)
Old 03-13-2010, 12:55 PM
There is no tape or dnc button. how do I change it in the register.
Dwayne.
  #7 (permalink)
Old 03-13-2010, 01:53 PM
Stainless
Usually the OEM fits an external switch that sets the G register bit on, this is a register in the PMC (ladder) that is read by the CNC side to indicate DNC mode.
Generally you require an integrator that can modify the ladder for you.
Minder.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
Ad Management plugin by RedTyger
