Hi everybody, i have an intermittent problem with a turret on a Schaublin machine and i need some advice.
I don't have so much practice on this machine and maybe somebody can give me some tips...
Informations about the problem:
Machine type: 180 CCN R-TM
Annee: 2012
Turret type:
BSV-N 160-12/25-220-380/50L
K05-GO/RO
Problem: The machine is often in alarm “EX1300 Command turret in alarm”
- The alarm can not happen during cuple hours and can happen a lot of times in 1 hour
- The problem is not in the same turret position
What i already did on the machine:
- I replaced the turret driver (Duplomatic), after that we can use again the machine (we couldn’t use it at all before).
- I checkedthe turret mechanic in intern, i opened the turret and check all parts, but not in the Duplomatic device (motor and gears box).
- I checked the sensor signals (position encoder, the index sensor and the blocking sensor).
- I tried to set up the sensor positions.
I'm planning to replace all sensors of the turret (solenoid, blocking and position), but i'm still thinking to try to set up the sensors positions again...
Maybe somebody already got the same problem?
Thanks for reading (and answering as well )
Annee: 2012
Turret type:
K05-GO/RO
