Dwell for G-Code l??
Results 1 to 7 of 7
    Jan 2003
    Genoa, Illinois
    1,472
    11
    257
    Default Dwell for G-Code l??
    I'm turning grooves in a 3/16 dia workpiece that is kinda long. I would like to have a short dwell at
    the bottom of the groove. I thought I could add #250 to the code thinking the tool would remain at the bottom of the groove for a few milliseconds before retracting but it does not work.
    When Mach 3 sees the first line with the #250 it stops and says there needs to be an equal sign.
    Where does the equal sign need to be? I tried to add the equal sign like this #=250 or =#250 but Mach3
    still does not accept the code.
    This should be an easy fix but I'm lost.
    Jim
    Jul 2005
    SE Michigan, USA
    651
    266
    177
    Not sure about Mach 3, but the usual g-code for dwell is G4.
    On Fanuc:
    G4 P500 (or G4 X500) will give you a .5 second dwell. No decimal is allowed in the P value (or X value), and the unit is milliseconds.
    Other controls (Milltronics, for example) allow a decimal, and the unit is seconds.
    G4 P.5 will give a .5 second dwell.
    Oct 2010
    Dewees Texas
    1,789
    23
    438
    On my machines g4 g04 are the codes for dwell also. If this will not work a easy work around would be to slow the feed to .0001 per rev for the last 1/2 thousanths of feed assumming this is a lathe. If a mill do the same thing just slow feed the last little bit.
    Aug 2002
    West Unity, Ohio
    23,102
    3402
    6392
    Any Fanuc that I have used dwell on takes decimals just fine.
    G4 X.5 = 1/2 second
    Can substitute U for X
    I think our older Mits only takes U's.
    If your Mach doesn' take this code - I would be surprised...
    I am Ox and I approve this h'yah post!
    Nov 2004
    Carnoustie, Scotland
    1,045
    12
    G4P*** as has been mentioned is for a dwell, the **** will be the amount of dwell you want, it can either be in seconds or milliseconds and you choose which on General Config page.
    Hood
    May 2011
    Nova Scotia
    387
    249
    155
    Didn't the length of dwell with G04 depend on whether you were feeding in Inches per Revolution (lathe) or Inches per Minute (mill)? I thought one timed the dwell in seconds and the other in spindle revolutions. (Been a long time...)
    Nov 2004
    1,045
    12
    Quote Originally Posted by Sean the Dog View Post
    Not in Mach anyway, its time based (S or mS depending on config)
    Hood
