stevo1
Cast Iron
- May 27, 2008
- Great State Of Wisconsin
Hey guys I need some help. I have a VMC and a 5 axis HMC both with Fanuc 15mf controls. They both have a rotary axis. I have the VMC machine 0 point at the center of the table. On the HMC I have the head rotated -90deg to represent a VMC and have the machine 0 at the center of the table. The HMC is a 93’ and the VMC is a 00’
I set 0 up by using a precision setup bar in the spindle and spin the table with an indicator mounted on it. I get this less than .0004” around, vertical is .0002”, and spindle run-out at the end of the bar (12”bar) is about .0008-.001”. Run-out could be better but this is not my concern at this point.
Problem is the 0 point is changing from day to day and sometimes not at all. It will vary +/- .006 radially. We do mainly bolt circle drilling. Tell the machine to go to the BC radius and then just keep rotating the table. As you can see this is a major problem with trying to hit my BC diameters. If it runs -.006 then this makes my BC small by .012” and my tolerance is .01”.
I have tested for backlash and found no issue. This is about the extent of my knowledge to check when it comes to machines not repeating. We had the machines laser checked when we first set them up about a year ago and the results were surprisingly accurate. The HMC is the one that needs the most attention. When I originally set this up I would go to a given X,Y, Z, A, C and zero the indicator on the bar. I would then do moves all over the machine, tool change, power cycle. Send the machine back to the coordinates and indicator would read 0,0. The machine can still do this. Is the Z,Y of the machines drifting??
Any help on what to look for is much appreciated. Please be descriptive.
Thanks guys,
Stevo
Thanks guys,
Stevo
