I am hoping someone can help me with my Emco Turn 325 and getting it to allow using a bar puller. I am using the following macro in a G65 call:
O0001 (BAR PULLER MACRO)
(G65 CALL WITH #1 = BAR GRAB and #2 = BAR PULL)
M5 (STOP SPINDLE)
G94 F20. (FPM MODE - EMCO)
G0
G28 U0. W0. (GO TO TOOL CHANGE POSITION)
T0808 (SELECT BAR PULLER)
G0 X0.
G0 Z0.010 (MOVE TO BAR)
G1 Z#1 F9. (SLOW FEED PULLER OVER BAR)
M25 (UNCLAMP COLLET)
G4 X.5 (PAUSE .5 SECOND)
G1 Z#2 F20. (PULL OUT BAR)
M26 (CLAMP COLLET)
G1 Z0.010
G0 Z2.
G28 U0. W0. (MOVE TO TOOL CHANGE POSITION)
G95 (RESET TO IPR - EMCO)
M99
M30
The control stops at the M25 command and times out with a 1023 auxiliary function alarm. I've checked and Emco does not provide an M31 (interlock bypass for chuck).
I am thinking it is probably something simple, but I'm stumped. Any help is appreciated.
M5 (STOP SPINDLE)
G0
G0 X0.
M26 (CLAMP COLLET)
G1 Z0.010
G0 Z2.
M99
M30
