Garadactyl
- Oct 18, 2017
Good day,
I am operating a Profiroll machine that we use to put a 5x6 knurl on a shaft diameter. the pre-knurl diameter of the shaft is 5.33mm and knurl diameter is 5.65mm once machined. I am not sure if any other information would be needed to answe the upcoming question as I am new to the CNC world.
The problem we are having is some of these knurls are coming out all hairy. Even though the go gage fits on and the nogo does not, this is still an issue as our customer would reject them. We have made sure the 2 dies are lined up correctly, made minor adjustments to the dies and the angles, tore apart the machine and set it back up etc. with no luck.
Now, we run 4 different parts on this machine. 3 of them have a larger diameter spline than this one (7.39mm pre-spline) with the only difference being the length of the knurl. The other 3 parts do not have this issue.
What are we missing?
