gradstdnt_99
Hot Rolled
- Aug 17, 2004
- USA, Midwest
I'm fairly new to programming and am seeking some advise to prevent breaking small endmills. I've been trying to cut a pocket in steel with a 1/8" four flute endmill x 1/2" LOC Carbide endmill. I know I'm shy with spindle RPM with a max of only 4200 RPM but set up the feeds to accomodate a .001 feed per tooth cut. Problem is the equations I've used to calculate my feeds based on spindle RPM and tooth load don't say squat about depth of cut.
My problem is that I can only take very a very light depth of cut, .020 or less, otherwise I'm destined to break an the endmill. How is depth of cut, especially for small slender endmills, factored into figuring out feeds and speeds used.
Your insight and experience appreciated. Learning the hard and expensive way by breaking carbide is getting old.
