Engraving with a 1/32 ball mill
Page 1 of 2 12 LastLast
Results 1 to 20 of 21
    May 2012
    Mid-Iowa, USA
    3,554
    3453
    2049
    Default Engraving with a 1/32 ball mill
    Exactly as the title states. Material is 304 laser cut, machine is a Haas VF-6SS with a 12k spindle. Obviously spinning at 12k, but what would everyone's feed be at .01" deep? HSMAdvisor always seems to me to be very low on these numbers (1.41 IPM? Yes this is with chip thinning turned on). Tool has a 1/4" shank and a real short flute length, solid carbide AlTiN coated.
    Dec 2014
    CANADA
    British Columbia
    713
    249
    332
    10 IPM is only .0002" per flute, any 1/32 worth it's salt should be able to handle at least that. Watch your entry feed, most of the 1/32s I blow up are on the entries not the engraving itself.
    May 2012
    Mid-Iowa, USA
    3,554
    3453
    2049
    Whoops, it's a 2-fluter. 4.8IPM is .0002"/flute.
    Sep 2005
    South Carolina USA
    4,498
    2154
    1304
    Not sure of your part specs, but the Micro 100 engraving tools sure work well.. I just finished up some tiny numbers engraved on hard S-7 at 55 RC.
    May 2012
    Mid-Iowa, USA
    3,554
    3453
    2049
    Quote Originally Posted by Davis In SC View Post
    Gotta happen tonight. Only learned of the job last night (relatively typical around here) and it's cosmetic lettering. Nothing horribly special, but has to look good. I have two cutters to play with. That means I won't break one, right?
  6. Likes Mtndew liked this post
    Dec 2014
    CANADA
    British Columbia
    713
    249
    332
    Normal engraving for me is 10k and 10 IPM with a 4 flute (.00025 ipt) so if those two extra inches matter for quantity...
    Edit: looks like it's a onesie-twosie.
  8. Likes dstryr liked this post
  9. #7
    Jan 2010
    Gilroy CA
    4,134
    2882
    2163
    I used to always use a ball endmill but recently I've been using a #1 carbide center drill and been very happy with the results.
    #1 carbide about .003-.004 deep and you can really go fast.
  10. Likes Hertz liked this post
  11. #8
    May 2004
    Paradise, Ca
    2,008
    558
    950
    Why .010 deep with a 1/32? Why not .005 with a 1/16 and triple your feedrate?
  12. Likes dstryr, chip_maker liked this post
  13. #9
    Sep 2007
    Northern VA
    476
    56
    That sounds deep to me as well. I end up going only a few thou deep to get a pretty decent width line. Sneak up on it, and either ramp in or slow down the plunge like Haazart said.
  14. #10
    May 2012
    Mid-Iowa, USA
    3,554
    3453
    2049
    Quote Originally Posted by Hazzert View Post
    Just a onesie.
    Quote Originally Posted by dstryr View Post
    Don't have any of those.
    Quote Originally Posted by [email protected] View Post
    I can do that too, but then work will have to buy me a new one (not that that's a problem).
    Quote Originally Posted by Nami View Post
    Plunge right now is set to ~1.4 IPM.
  15. #11
    Feb 2012
    CANADA
    Ontario
    1,094
    83
    410
    Just ran the numbers and was going to lambast you for going so deep, but others have done it for me.
    HSMAdvisor would probably suggest higher feed and lower depth of cut.
    IMO. 0.01" deep with a 0.03" tool in 304SS is way too deep. Hence it suggests such a low feedrate.
    Otherwise you would probably snap the cutter right away.
  16. #12
    Jun 2006
    Thunder Bay Canada
    1,720
    469
    263
    I found that 0.003 to 0.004 was adequate for engraving with a 1/32 mill. The trick is that the surface has to be dead flat for such a shallow cut otherwise the letter widths will be all over the place.
  17. Likes Davis In SC, John Welden liked this post
  18. #13
    May 2012
    Mid-Iowa, USA
    3,554
    3453
    2049
    I'm going to change it to .005" with a 1/16" cutter. This is going straight on the subplate, so if it varies I'm going to blame Chick Workholding. Which I wouldn't mind doing anyway
    Edit: got the part indicated with a tenths test indicator (I have a VERY short flat to work with) within two tenths end to end, and checked the flatness of the part. Around the area to be engraved it's all within five tenths. Should work okay.
  19. #14
    May 2012
    Mid-Iowa, USA
    3,554
    3453
    2049
    Wish I could take a photo to show, but it came out awesome. 12k, 10.7 IPM, .005" deep.
  20. Likes Mtndew, zero_divide, Hertz liked this post
  21. #15
    Feb 2012
    CANADA
    Ontario
    1,094
    83
    410
    Quote Originally Posted by Atomkinder View Post
    What do you know!
    That's exactly what my calc suggests for a 1/16 ballnose
    Thank for coming back with the results.
  22. Likes Atomkinder, Mtndew liked this post
  23. #16
    Jun 2012
    Michigan
    8,350
    2479
    2778
    Don't know if this is related to OP but I see some software that claims to be able to use a JPeg ( photo the make the program. ) Is the true and easy?
  24. #17
    Nov 2011
    Missouri, USA
    2,782
    1354
    2710
    We regularly do deeper engraving @ 0.015 deep so it shows up after being painted, and sometimes even deeper so we can paint it, then fill in the remaining volume with a lacquer stick or contrasting paint.
    Looking at the last few we did, depending on situation, it was .003 - .005 depth per cut down to .015 depth, .0002" per tooth, and ~5ipm @ 10k rpm. That's with a 1/32 ball mill as well. The strategy might be 'playing it safe' but it's also a "onesie, twosie" where it had about $30k in each part before the engraving. Risk assessment resulted in taking it a little easy on the engraving with a 1/32 ball mill - acceptable time cost.
    ETA: Whoops, missed your followup post. Glad you had good success.
  25. Likes Atomkinder liked this post
  26. #18
    May 2012
    Mid-Iowa, USA
    3,554
    3453
    2049
    I'm here at work on my day off doing a different version because the engraving came out so nicely, so they're paying me OT to make them now.
  27. Likes John Welden, Mark Rand liked this post
  28. #19
    Aug 2011
    Toledo, Ohio
    1,669
    39
    578
    .125 Spot Drills 90 do some awesome logos/engraving. I have the operator a firm believer
  29. #20
    Feb 2013
    Madison, WI
    626
    831
    375
    I have had the best luck engraving with drill mills.
