Hello,
I am looking for some help in getting serial communications set up with my yasnac MX3 control. I have it set for 4800 baud, 2 stop bits, not sure about the parity setting at the Yasnac side. Was trying to use hardware flow control but I'm not sure if that's what the Yasnac wants. There is a control code parameter I've played with but I don't know if that is in addition to or instead of the hardware control. I assume the serial port that I have is 'serial port 1' (there is only one on the machine but two are defined in the control). I am getting a "TH Parity Error!" message which makes me suspect the parity is set wrong - but I've tried changing the setting at the PC without any difference in behavior.
Anyone have some advice on how they got this working?
thanks!
thanks!
