example of tapping cycle for an O-T control
Results 1 to 6 of 6
    Jan 2011
    Fort Collins, Colorado
    350
    161
    37
    Default example of tapping cycle for an O-T control
    Hi I want to tap some parts on my puma 10-HC with a fanuc O-T control
    303 stainless 4-40 tap
    can anyone give me examples of the canned cycle used? I believe its a G84 but Im not sure on how its setup
    if not I can always do it the long hand way
    thanks in advance
    Nick
    Jun 2006
    Melbourne Australia
    541
    139
    30
    Hi
    Are we talking a single tapped hole on the c/line along the Z axis?
    Regards
    Mike
    Jan 2007
    Massachusetts
    5,105
    642
    1014
    I don't know if that's a lathe or a mill, but the G84 cycle is pretty simple. Assume 32 threads per inch.
    M3S1000
    G84 Xx.x Yx.x Z-.35 F32.0
    G80
    It would be similar for a lathe, though you'd eliminate the X-Y positions and use F0.032 (feed in inches per revolution.)
    You'd need a compression-tension holder unless the machine has rigid tapping option. If it has that, you might add M29 into a line before the G84.
    If it is a mill and you want more holes, you just give a line with the X-Y positions for each hole. The G84 is modal and repeat the Z and the cycle for every position until it sees the G80 cancel code.
    Jan 2011
    350
    161
    37
    yes it is a single tapped hole on center z axis on a lathe
    Jun 2011
    Winnipeg, Manitoba
    70
    23
    G00z.25
    g32z-.5f.025m5
    z.25m4
    Sep 2005
    Arizona, USA
    37
    11
    15
    Hardinge with 0T and releasing tap holder:
    (5-16TAP)
    N120G97S150M13
    N140T6
    N150X0.
    N151Z.05
    N160G32Z-.75F.0546
    N170G4X.8
    N180M14
    N190G32Z.05F.0556
