lspotts38
- Mar 7, 2012
- Northcentral Pennsylvania
Having trouble with a "ring" shaped part, should have been really simple but is driving me up the wall. Material is a stainless of some sort, harder than I remember 303 being built not terrible to machine on tools, AMS spec of some flavor or another. Seems to be running at normal SFM's for stainless. Problem that I am having is maintaining any kind of roundness after parting off the ring. 2 1/4 OD, 1.590 ID, 1/2" long running on a barfed subspindle machine. Material is solid barstock. Process is rough turn the OD, drill the ID, finish bore the ID, part off/ subspindle transfer holding on the ID and finish turn the OD. I have +/- .0005 on the OD, and cannot hold the roundness within the upper and lower limits of the diameter tolerance. I can get anywhere from .0007-.0015 out of round on the OD. I believe that the part is round right up until I part it off the bar, confirmed by running an indicator on the turned diameters and getting less than a tenth indication. I don't think it is the subspindle turning op, same indicating and checking for the runout yields negligible indicator movement. Low chucking pressure, and the out of round condition on the diameter is measuring at 180 degrees, three jaw chuck I would expect it to be at 120? Seems like the material has some stresses in it that don't come out until the part is relieved from the bar. Tried different order of ops, like parting close to off and finish turning hoping for some stress relief. Less aggressive feedrates to no effect. Current theory (yet untested) is trying to drill the core with a smaller drill, thinking that the 1 1/2 drill may be putting more force close to the diameter that I am parting off at. I'd rather not add a third turning op, fairly high volume part. Anybody have a situation similar before that they would be willing to share their fix?
