Second statement; how do you figure running that way is less catastrophic after a crash? Just curious about such unyeilding STATEMENTS, I thought people had preferences, and I am positive that MTB's have done much more research than I on the best way to run.
Hi Robert,
As far as damage to the Chuck, Tools, Tool Holders, Turret etc., there is no difference. However, and I'm sure Phil, aka machtool, a machine builder of some note here in Australia, will agree with me on this, that a machine having Box or V slide ways often sustain damage to the keeper plates, and or the mating surfaces of the keeper plates as the result of a severe crash, when the spindle rotation is such that its trying to lift the turret and carriage. This same magnitude of crash where the cutting forces are directed downwards towards the top surfaces of the slides is generally soaked up without damaging the slides.
I've seen quite a few machines I've been called to repair, with keeper plates having pieces from the area around the retaining bolts broken away completely, and if not completely broken, more often than not, cracked in these same areas. On machines that don't have the keeper plates surfaced with turcite, you will often see an imprint of the end of the keeper plate in its mating surface on the underside of the slide-way.
With regards to the MTB's doing what's best, it's more a case that machines have evolved around tooling rather than tooling made to suite machine design. Without question, a lathe having the cutting tools at the back of the machine would be better equipped with Left Hand cutting tools so that the cutting force is being directed downwards onto the top surfaces of the slide-ways; this is the basic load bearing design of just about all lathes. Overwhelmingly, right hand drills are more readily available than left hand, and from a production point of view, its better to not have to keep changing spindle direction to accommodate Left Hand turning tools, when the drills available were Right Hand.
With machines having Linear Bearing Slides, the difference in terms of damage sustained would be marginal, but still leaning towards downward forces having the least effect.
Regards,
Bill
