I go with fewer flutes for finishing aluminum. My experience with face mills with >4 flutes (in 2" & 3" diameter) is that they have more of a tendency to put chips back onto the surface. I don't know the correct term, but it is as if the chips or dust get welded onto the surface when you are trying to skim cut and leave a mirror like finish. It is like there is a minimum chip load per tooth and when I drop below that, I get that effect. Taking a heavier cut, or slower RPM, or more aggressive feed can fix that some of the time, but for ME, a four flute 2" cutter with 45 degree inserts, with a fairly positive rake gives the best result.
Thanks all. This is on a "20hp" Haas VF2, with 10k and I am looking at their 3" cutter.
Currently using a Maritool 2.48" and while it is great for removing a lot of material, it only leaves OK finishes. So I was wanting to pick up something that can take a finish pass after roughing with the Maritool.
I have these parts set into the vise .150"
Will this ASX be a couple steps up in surface finish, or should I be looking at an adjustable pocket?
Notice
