Looking at a couple 45 degree facemills. Mostly wondering how the performance is on the 45degree facemill that takes HNGJ, double sided hex inserts like the one maritool sells. Inserts cost a fair bit more than the high shear SEHT-SEET 4edge single sided insert, but the Hex obviously costs less "per edge" since it has 12 vs 4.
Trying to see if I should pick one and do it all with it, or if I need both styles?
I take it the 4sided one would do better in the soft materials, there's a few videos of it chewing steel but to me that type of very positive edge looks easy to break? then again lower cutting force can sometimes do miracles.
Hex style is more negative with a positive chip breaker, and I'd expect it to last longer in steel and stainless. But that also depends on insert grade selection in each type.
So which is better/more cost effective in the long run and will get by on the largest variety of materials? and also typically easiest to find good inserts for?
Facemills like that are not something I ever really had to use much on my manual work, mostly still just flycut when needed and even that is rare.
If there's another type I should look into that is well priced please let me know.
