dandrummerman21
Stainless
- Feb 5, 2008
- MI, USA
I'm machining some die cast aluminum, 360 or 380 material, approximately 3" x 7" x .400" thick.
I'm bolting through 3 holes that are already cast into the part. I'm holding at those 3 points with pads underneath the part, the rest of the part is not touching anything. There are 2 adjacent holes spaced 2.3" apart on one side, and 1 hole in the middle on the other side of the part, 6" away from the 2 adjacent holes.
The part is bolted to a fixture in our horizontal, and I'm using a 4" (and tried 3") iscar facemill, octogonal inserts.
I'm trying to achieve a 125ra surface finish and hold .0005 flatness. Both of these are easy to achieve (usually)
The problem I'm having is, occasionally (once every 2-10 cycles) I will get "gouge marks" from the facemill, in random places in the travel (it is facing in the y axis, due to how I have to hold the part). I run 2 parts per cycle. Sometimes these gouges are in the part on the left, sometimes on the right. The parts are tight, when watching it, there's no noticeable chatter, nothing on the machine is moving (tool changer, for example).
I've tried the following:
alumimum specific sharp carbide wiper insert, 1 insert, 4" feedmill (treating it like a flycutter, basically), both dry and with coolant
aluminum specific sharp carbide inserts, 1 insert, 4 inch facemill, dry and coolant
alumimum specific sharp carbide insert, 6 inserts, 4 inch facemill, dry and coolant
general purpose insert with honed edge, 6 inserts, 3 inch facemill, dry, coolant, and dry with airblast
I'm only removing about .02" of material as that is all that was given.
I've tried all of the above with different amounts of cut, .02 all at once, .018 and .002, .015 .004 .001, etc.
Currently, my "best" setup is with the 3" using honed inserts, dry with airblast. But 10 cycles isn't great.
The "gouge marks" are less than .001 deep, as a .001 deep skim pass gets rid of them 90% of the time.
Does it sound like I'm getting a chip stuck to the tool? Would it drag a chip under it like that? The only other thing I think it might be is the part getting "excited" in the middle and vibrating momentarily, but I've never heard a sound out of this operation and it is sometimes near the entry or exit, where it would be the most rigid.
Ideas? Diamond tipped insert perhaps? other ideas? I'm all ears.
