Richard/SIA
Cast Iron
- May 13, 2007
- No. Nevada
Ran a decent size job recently with no issues.
Got a short job to run but the tool changer unexpectedly closed while in TC,1.
Hmm, must have touched a button, do it again, I thought.
No tool umbrella movement from TC,1.
I do get an error message at the control.
Reset CS, tried again, no luck.
Found a 2A circuit breaker tripped, reset it.
No change.
Removed the upper cover so I could manually operate the umbrella without having my arm stuck up inside the machine.
Nothing stuck.
Found and cleaned the two position sensors, no change.
I did find out that if the umbrella is not fully home the TC,1 command will return it to the parked position so I know the servo motor is still working.
I would look this up in the manual, except, guess which pages are missing?
So I'm looking for hints to diagnose why the umbrella is not moving.
Hoping it's simple.
For now I will be running the parts on an Old Matsuura.
No change.
Nothing stuck.
Hoping it's simple.
