ian3846
- Apr 6, 2009
- Australia, Gladstone
hi guys
the boss gave me a drawing today and said make 40 of these the part was simple 18mm max diameter with 1 step and a few champers tapped m8 though. then i saw the tolerances +.005mm -0.000. i asked why the tolearance is so tight espesically with nylex (nylon) he said its a press fit. I said can i have a realistic tolerance...... well you know the answer i got. So set up and started making these parts and after a about 20 minutes i had a about 4 in tolerance and at least 12 out of tolerance not by much .001 .002 etc lots of varience for no reason. they ended giving the first 40 the ok so i guess the tolerance had changed?
Anyway i was wondering if it possible to pull this of and keep 100% within tolerance and if so how?
