Houndogforever
Hot Rolled
- Oct 20, 2015
- Boring
So I look up the seal that is supposed to go on the Fadal thrust bearings. Measuring my existing part, the OD of the seal must be 1.50 dia and .25 thick.
Now the inside diameter of the seal is listed as 1-1/8 ID, however when measuring my ball screw and the end nut the outside diameter is 1.060 diameter. So the seal doesn't even touch the ball screw? How can that keep grunt from getting into the ball screw thrust bearings?
