Dave K
- Mar 21, 2004
- Waukesha, WI
Years ago, I remember floppy disk drives having a capacity of 360 kilabytes. This was some time before the 1.44mb floppies came along. During the transition, supposedly the 1.44 flopies could be formmated to run as 360's, if you so chose.
I have a floppy disk, 1.44mb, that I suddenly can't write to. I cannot save a single program to it, no matter how small. The write protect is set correctly, so I know that's not the problem. I suspected the disk was bad, so I did a copy from the old disk to a new disk. Now the new disk has the same problem. I can view this disk just fine, and I can read from the disk just fine, just can't write anything new to it. Not even a word document from the computer.
So, I was wondering if the Fadal was accidently formated to a 360, when it should be 1.4mb? The reason I suspect this, is because on the bad disk, if I put it in my computer and click properties, it says there are 359kb of information on it.
Am I on to something here? Anyone else experience this?
