Fanuc 0M on Chiron FZ-28L need parameter to set tool in spindle
Results 1 to 11 of 11
    Jan 2015
    Massachusetts
    6
    Default Fanuc 0M on Chiron FZ-28L need parameter to set tool in spindle
    We have a 1994 Chiron FZ-28L with a 40 tool carousel and a Fanuc 0Mc control. It's a German built machine my company had shipped over 18+ years ago, so the documentation is a little lacking.
    Our issue all started 3 days ago after a fail during a tool change which occasionally happens. One of the many air cylinders involved in the tool change does not register that it completed a move and then the tool change times out. During the manual process of completing the tool change a M57 (delete spindle tool) was commanded (by accident). Now the machine does not know what tool is in the spindle. How do I set this?
    After I walk all the steps through the unfinished tool change so it is ready to use. I then command a M06 T02 in MDI mode. It will go and pull tool 2 from the carousel and put it in the spindle. The tool coming out of the spindle never gets put back in the carousel. The carousel just goes around and around and never stops at the correct spot to put away that tool. I have stopped this process and manually completed the putting away of that tool into the carousel. And since I just had the machine put tool 2 into the spindle I hoped it would know that. It does not. When I command another tool change M06 T03, the machine pulls t03 out of the carousel and places it in the spindle. It then doesn't put t02 away. So either it can't remember the carousel spots, which is weird because it does go to the right spot when pulling tools out, or it can't remember the tool in the spindle which is what I think is going on.
    Anyone have any ideas? I hope someone knows what parameter to set on this control to set the Tool number.
    Oct 2006
    New Hampshire
    173
    70
    42
    I’m working from memory here, but I think it’s 440 Or D440 something like that. I can confirm for you when I get in the shop in the am. I have it written down as it happens on ours often.
    Mar 2013
    Oregon
    1,174
    493
    1227
    A tool change issue with a Chiron? NO! NOT POSSIBLE!
    Oct 2006
    New Hampshire
    173
    70
    42
    Quote Originally Posted by gkoenig View Post
    To clarify we don’t have a Chiron but we have Fanuc OM’s. Thanks for your help.
    Jan 2015
    Massachusetts
    6
    Quote Originally Posted by BALNH View Post
    Can confirm which parameter you use to reset tool in spindle and how. I would greatly appreciate any guidance. Both Parameter 440 and Diagnostic 440 are currently set to all zero's (00000000) on my machine.
    Doug
    Oct 2006
    New Hampshire
    173
    70
    42
    Have written diagnostic-440=spindle tool #. I seem to remember it being a data parameter and not an 8 bit parameter. I could be wrong haven’t had it lock up in a couple of years. Index turret/pot tool to T1 and make D440 read 0000001
    Jan 2014
    Vancouver, WA. USA
    2,699
    540
    1343
    The assignment of what Diagnostic is used to track the tool in the spindle is determined by the machine builder, not Fanuc.
    D400 is the beginning of a data table area of Diagnostic parameters on the 0 series controls. Some builders use that table to track tool positions but it is not universal.
    Mar 2013
    Oregon
    1,174
    493
    1227
    You don't, but the thread is about a tool changer problem with a Chiron...
    Jan 2014
    Vancouver, WA. USA
    2,699
    540
    1343
    I am constantly amazed at how many CNC users have no clue about how the control and machine interact and what is determined by Fanuc and what is determined by the machine builder.
    Oct 2006
    New Hampshire
    173
    70
    42
    True but I got the om, I was tying to help a fellow New Englander out. My heads still a mess after staying up to watch te super bowl on Sunday.
  11. #11
    Oct 2006
    New Hampshire
    173
    70
    42
    I stand corrected. By no means an expert or tech just trying to help.
